TM Growth bearings?
Discussion in 'General Fabrication' started by BlueSteel, Apr 5, 2017.
  1. BlueSteel
    BlueSteel Well-Known Member
    Dec 15, 2016
    104
    88
    Anyone know where i can get bearings?
  2. CJKnoll
    CJKnoll New Member
    Dec 1, 2015
    I would take the measurements of the bearings and order them from a bearing supply online or through a local hard ware store. Where did you end up having a bad bearing? Tuning the cassette is not an easy task, if thats where its at you might be better off calling Tormate's tech department.
  3. BlueSteel
    Dec 15, 2016
    104
    88
    Not sure which bearing is bad yet but it makes a screaching sound when I move the gantry in some spots. So I think it's time to replace and clean a lot of the bearings. The cassette seems ok.
  4. BlueSteel
    Dec 15, 2016
    104
    88
    Offhand do you know what size the allen key is that holds these on? I need to order some
  5. LECS-Chad
    7/32 is the allen
