Limit Switches Not Working
Ok go to CONTROLLER/INPUT LINE STATUS.
This displays all of the inputs of the machine. You can now go around and toggle the switches and will change from green to red.
Also if this just happened to verify that the connection on the back of the signal generator is plugged in. I would understand 1 going bad but all...
Ok
So the only things listed are pierce signal and fault signal both are listed as open checked the wiring and everything appears ok
Also I can not toggle anything if that helps
ok
Listed
TMX 5x10.stp
Tourchmate.stp
Tourchmatex-servo.stp
Torchmatex-stepper.stp
Under recent setup I show in order
Torchmate.stp
Thanks For the help Guys
Probably need to use the TMX 5x10.stp file basically one of these files should have you limit switches defined, you can look in Configuration > I/O > Input Lines.
I gathered that after you guys pointed me in the right direction. Any thoughts after 4 years it would change?
ok So only torchmate stp lists anything in the io the torchmatex 5x10 says its for a newer version. After asking some questions apparently the boss formated and reinstalled everything to this pc. So I think if I install the latest driver software I should be ok
