Jogging along tool path
I have a torchmate 4800 and I was wondering if there's a way to jog the torch along the tool path in torchmate vmd so that if something goes wrong with the cut and the torch stops I can jog back to the spot that's not cut and recut that section.
Hopefully that makes sense as to what I'm asking.
Thanks
In the VMD software you can use the Run from Here feature, no need to jog the torch. With a touch screen simply touch and hold on the cut line, a menu will pop up choose Run from Here the torch will move into position where you can press Run Job to continue where you left off or you can use this to skip over parts. The touch and hold is for a right mouse click if you have a mouse use the right mouse button. Note: you may have to zoom into the part to see the cut line better or if it pops up Search Failed.
