Box dividers
When you do a bend line (cut) is that just a line with online cut path or is there a closed narrow rectangle to it? I have never tried that. Looks great!
Just a straight line with an online tool path. Works great for stuff like this. I usually leave 1/4" at the connection points. Then just break it over the edge of a table. Any less than 2 or 3" on either side and it works best to sandwich it in a vice between two pieces of angle iron that are longer than your part.
and if you want the "solid" look then you can fill weld the bends and grind. smooth operator.
