Drill bit sharpening jig.
Discussion in 'General Fabrication' started by toglhot, Mar 22, 2022.
  1. toglhot
    toglhot Member
    Mar 7, 2022
    I made this drill sharpening jig several years ago. I used a piece of 25mm square bar, linished it, milled a V for the drill, cut a 2mm slot down the centre for 110mm, drilled a stepped hole through: 5mm for 30mm and then 11.5 mm for the remaining 110mm. I had to extend an old 11.5mm drill and grind flat on the end so I could machine the end of the hole flat for a stepped bush to run on. I also drilled a couple of debris drain holes and tapped a few 5mm holes for mounting the slide plate, the end plate and the drill clamp. As you can see from the pics there are quite a few bits inside.
    The 5mm advance rod was turned down to 3.5 on the end and a 5mm bush with collar was shrunk in place for the end bushing. I turned a bit of stock to 7mm, threaded the inside to 5mm x .8, fashioned a single wing and tacked it to the nut. The bush on the advance end was machined to 7mm with a collar, machined down to fit a 9mm spanner, and threaded inside the same as the advance screw. When screwed into place it’s locked off with a locknut. The plate on the end has a backlash adjuster and locknut and also acts as the outer bearing for the advance screw bush. The end plate is fixed by two 5mm allen heads which I had to turn down to accommodate the backlash adjuster locknut. To the rear of that are the thumb lock nut and the thumb adjuster.
    The drill clamp U piece is attached via two 5mm allen heads. I machined a stepped 5mm nut and shrunk it into the top of the U piece. The adjuster screw has a thumb nut attached at the top and the adjuster screw pushes an H shaped plate down onto the drill flutes.
    It will accommodate drills from 13mm down to 2mm, but in reality anything under 3mm would be easier ground by hand.
    I also had to make a table to slide the jig along, just a couple of flat steel sections welded to a support and a gap down the centre filed to an exact size to allow the jig to be slid side to side without any play.
    To complete the build I made the wooden storage box and wrote drill sharpening jig in Chinese script on top, we all know only the best tools come from China, right?
