Hi Everyone,
I am new to the site and have a few questions. I have been struggling to get my table up and running for actually over a month. Its a Growth Series 2X4 with a Cutmaster 102 attached to it.
My first problem was the machine diving every time on start or giving a "Limit Exceeded in Z, Position =-10.0000", it seemed like a Ohmic Sensing issue, which I bypassed by setting the height manually.
Once I did that I was able to get the machine to do successful dry runs... with the exception of it retracting at the end of the program followed by it plunging into the table right after.
Well anyways, if you have stuck with me this far, my current issue is when I do the active run, the torch comes down, pierces the plate and just stays on, doesn't move or anything until I have to manually stop it. My guess is the machine is not receiving the "OK to Move" signal from the cutter. At this point I really just want to see the table cut something, I am desperate to cut my first piece and want to know how to disable the need for it to get the "OK to move" signal.
Thanks Everyone!
Thanks Everyone!
