OcalaWill
1) Gantry is mounted. As I push the gantry from front to back extremes there is a small gap where it stops on the left rail. About 3/32" at the back. If I pressure by hand it closes the gap but springs open once I let off. If I try to adjust it out by tweaking the bearings then the gap opens up somewhere else. I have spent hours trying to dial this in. Crosswise and side to side measurements seem to be square. Is this an issue?
2) I am not clear on how to mount the tool mounting plate. This was not mounted on my machine and it is hard to tell from the PDF the orientation of this.
3) There are 8 bolt slots on the lifter station. Which slots do I use to mount it? I am using the LC105M torch.
4) Does the plate marker (or other tools) use the right angle bracket? How do you mount the right angle bracket and still use the standard torch mount position? Seems the bolts mounting the right angle bracket to the tool mount plate would prevent the lifter station from mounting flat.(?) Or does the right angle bracket get clamped between the lifter station and the tool mount plate using the 4 socket heads?
Thanks!
W
Thanks!
W
