ryan thomas williams
Member
Hello all,
I have a 4x4 with height control and half way through a multi piece cut the machine will bottom out on the steel and it looses its Z axis. From here i have to raise the torch all the way up and reset Z. Then i go and reset the torch to steel height and hit run. Is this normal? When i raise the torch all the way up the motor sounds like a clutch breaking free and z axis gets screwed up. Is this normal?
