Fastyankee13
I'm not explaining this right. If I jog the torch to a spot on the table were I want it to start from and set X0Y0 it will move away from that spot and start burning. I just used this simple G code as an example this is happening on every part I create. It will move a few inches and start burning like it has an initial lead in that I did not set up. Does it figure in material size when it starts. I'm used to were I set X0Y0 that is were it should start its first cut it doesn't .
