at first I thought it was warped material , I did do a reset of system , how or is there a way to adjust x axis pressure on plate for ohmic sensing? For when I am cutting thin plate it will actually push it down between slats and cause a breakaway error.
thanks, will give it a shot. I am showing ohmic connection however torch lowers down onto material and stops
You can change the sensitivity of the Z by going to Machine Settings, clicking on Inputs and change the Cap Sense Debounce value to 10, also can increase the Debounce time for the Breakaways to 200.
