While cutting I lost arc, the torch moves ahead just a little so that after I fix it when it starts cutting it misses about .0625 of cutting. Is there a way to back the torch up in the cut path to start again and not miss any cutting?
Support got with me and told me how! So with a mouse move to where you want to start your cut, right click, move to here. It will count down while looking through G-code and move to somewhere really close. Then right click and click run from here. Then you are cutting over your arc loss and away you go! This might not be exactly the right wording on this but if you try it you can figure out what Im trying to say. Good luck cutting!
