Easy Dross Removal, No Sanding/Chipping/Scraping
Arkansas Metal Art
If you like this tip, please click the like button below.
Quick tip: Needle scalers work great for easy dross removel. No more sanding, chipping or scraping. $$ saved on flap discs. Easy cleanup. Dross stays on the table instead of the floor.
I picked up a $28 needle scaler from Harbor freight and it works great. It leaves small marks on the metal but since it's the back of the part it's not an issue. They easily sand away if you want. Just be sure to clean the oil off the scalers before using.
Don't dread the dross!!
If you like this tip, please click the Fab Forum like button below
Apologies for the vertical video. Had to one hand it.
I was looking at one to make patterns in metal like fish type scales. Now that it will serve two purposes will have to pick one up
needlers and tiger claws are my go to to remove dross. More the tiger because it doesnt leave a pattern.
I’m going to give this a try
