Datum issues
GarageNerd
Started up the machine this morning and running into datum issues. Hit datum it starts the process and stalls on moving to datum position afyer a few movements. Hit stop and i can jog the machine at 50 ipm on y axis. And it seems like the motor isnt kicking on on the side closest to the monitor. Turned everything off and checked the plugs on accumove and reseated them no love.
You can either Logon as Admin (password 1234) click on Machine Settings and click on Factory Reset, restarting the VMD software see if that fixes it or you can click on Load Configuration under Machine Settings, uncheck the box for your table select the name on the configuration file so that it is highlighted in blue, leaving the box unchecked and press Ok, then click on Factory Reset and restart the VMD software.
