The jeep started as a 2000 tj sport, the goal is to get a decent daily driver the has pretty good trail capability, the motor should be about 200 hp and north of 400 lb ft of tq, I am looking for a good set of super duty axles that I will cut and narrow for a custom fit and spline new axles in my mill, new long arm suspension is getting built for front and rear as a start
What are you using for a transmission and transfercase, and how are you adapting them? I have similar plans using a 3.9 4bt and would like to use and automatic.
I am using the nv3550 till it let's go, the case is stock till I find a suitable replacement, the 4bt I bought cam with the ford t19 transmission so I used the novak nv3350 to small block ford adapter
