1-AMP 250-Volt Fuse keeps blowing up on my Hypertherm
MDZ
Good afternoon,
Anyone have or had the same issue?
So as to not play 20 questions this looks like the fuse on a red screen height control box, what plasma cutter are you using. If it is a Cutmaster series make sure you are not using the spade connectors inside those units for raw arc voltage. You should be using Work + (plasma ground cable) and Torch - studs on the circuit board.
