Cypress
Well the ongoing saga with my table continues. I sent my accumove2 to a place in San Antonio for repairs. After 3 months I get my accumove2 back and it still doesnt work.
I send it off to Torchmate and they repair the controller and send it back to me quickly. Thank you Torchmate for all you do. I redid all my grounding as suggested. Hooked everything back up, had a few minor bugs and Denny from Torchmate was awesome in helping me address those, he even stayed after their normal closing hours to help me get my issues worked out.
Controller works, Machine head moves around the table like it's suppose to. Great...
Now the problem. Same as before.
Machine head moves to position.
Touches down, comes up to fire....just air. No arc
Look at my controller and the LED is off.
Controller Powerbrick is off and warm to touch.
No Fault on Plasma Cutter.
Plasma cutter works fine when not hooked up to the table.
I did not try to cut again. The last time I did that my Accumove2 smoked. I did switch out powerbricks and turned the controller back on and brought up the VMD. Controller is ok, and gantry moves around the table with no issues.
So the question...what would cause the power brick to trip, shut accumove down when the plasma tries to fire?
My Torchmate GS 4x4 has been 90% of my business and I'm pretty much dead in the water right now. I pray this never happens to any of you. I have faith the good folks at Torchmate will help me solve this maddening problem.
AJ
AJ
