Dan Turner
I learned something yesterday that is so basic that I hesitate to admit, but if it helps someone else then here goes. I have upgraded my system to the Accumove 3, which is a great move. I have been trying to chase down and trouble shoot why my unit was not recognizing the Ohmic sensor. I replaced all of the grounding wires and built a new grounding block for he star ground. I sunk an 8' ground rod and rebuilt my water table to ensure that everything was attached properly. I used my multimeter to make sure that I had continuity everywhere and everything tested fine. I made long wires with alligator clips on the end so I could test more things, but I still could not get the Accumove to recognize the Ohmic circuit. When I tested attaching a wire from the end of mthe orange wire by the cap to the ground on the back of the VFC, the light on the dashboard of the Accumove software would then say there was a connection.
I was working on it again yesterday and had a friend testing the torch end while I was at the computer. I went into machine settings and turned the relay on. when he touched the shield, the light would come on saying that the Ohmic circuit was detected, but when he would touch the nozzle, the light would go off. I then went onto the Hypertherm website and learned that you have to have a special shield for the Ohmic sensing to go with Ohmic sensing retaining cap.
This is what I learned, the Ohmic sensing circuit goes through the Orange wire to the Ohmic sensing retaining cap through the Shield and not the nozzle. Therefore, the shield needs to touch the metal instead of the nozzle. this completely solved my problems.
On a side note, turn the relay off when finished because when you run a job, the relay will automatically turn on and off while running the job.
I hope that my learning helped others.
