Not Sure What To Do Now?
Discussion in 'General Fabrication' started by gearheadmike, Jan 5, 2021.
  1. gearheadmike
    gearheadmike New Member
    Jan 4, 2021
    Little back story i'm working on a project car a 1950 Crosley it's a small car but did a larger 4 cyl engine swap and now building a disk brake set up. Brakes are from a 81 civic so not a large set up. I got some 4130 normalized chromoly 1/4" plate for the caliper backing plate. I got my template made and transferred over to the steel. But not sure how it should be cut and how the 2 large holes made?
    Thoughts on some stuff is will a abrasive cut off wheel gen to much heat and cause the cut edges to be annealed?
    What to use to cut the 2 large holes? Hole saw/drill bit/bridgeport?
