Not all plasma's are the same. Using the right power level and set of consumables as well as correct speed and height and you can achieve 1.5 to 2 degrees of bevel on materials 3/16" and thicker, on thinner materials the bevel angularity will be more, but difference between the top and bottom of the cut less, this with shielded air plasma. With a HyDefinition class plasma using oxygen on steel you can hold about 1 degree on materials thicker than 3/16" and 2 to 4 degrees on thinner. The thicker you cut, the less bevel. Above about 1/4" a HyDef plasma will cut much faster than a laser and with smother edge quality and similar bevel. Jim
