I am looking for a video on how to use the torchmate to manually cut material while still on the table.Any Help on where to look?
If you have the previous generation controls you can find a guide here at below link. If you have the new Accumove controller you can run the file attached, essentially you Set Program Zero where you would like the cut to end then jog the torch to the starting position and hit Run Job, the torch will drop and cut to where you set program zero. https://torchmate.com/machine-help/Manual-Plasma-Cutting-Techniques
