I'm looking to index square/rectangle tube on my 4x4.
I realize that I will need a reliable home location, so I'm piecing together a simple buzzer connected to 2x limit switches to allow for quick/easy homing on one of the corners.
So, after homing the torch to a known location and matching that corner up with the bottom corner of a piece of square tube, how would I go about having shapes cut from it?
As a quick thought (assuming I'm cutting 4x4 tube square tube) I was thinking of drawing a rectangle and centering my cuts inside this rectangle. Then after I drag the rectangle with cutouts to the bottom left corner of the TM CAD and finally delete the rectangle outline before outputting for cutting. Will this work? Will the registration be lost between the CAD and VMD software?
If all the above is too complicated how to best accomplish cutting square/rectangle tube?
Just to be clear, I am NOT wanting to attach a chuck and have the machine rotate the square tube, I am only looking to accurately locate and cut holes to allow round tube to pass through square/rectangle tube.
Thanks!
Thanks!
