I'm not sure what happened but every time I try to weld something it blows it up.. Any idea how to fix it? The measurements never move.. Any help would be a huge help!! Thanks in advance! .
So what is happening is that the inside of your letter is not part of the outside part of the letter. So when you BASIC WELD the center will drop out. Select your letters (not the bridge) and go to ARRANGE/MAKE PATH. Go to VIEW/SHOW FILL. This will show you exactly how the item will cut out. Then SELECT ALL (ctrl+A) then do your basic weld. We have videos that cover this issue that you are running into. Check them out at www.torchmate.com/unitversity Scroll down and go through the NAMEPLATE video. Covers this topic.
