PopishFabrications
Member
Hey guys,
Thanks for any info you can give. As of the last couple weeks our torchmate 2 table has started lifting away from the material for about an inch after the pierce. It looks as if the avhc is lifting it to find the voltage but its lifting far enough away that it makes a noticeable non straight part before it will finally settle at the voltage and cut just fine. Ive looked around and tried adjusting some of the settings but no luck. If anyone has any info that would be great. Planning on calling torchmate in the next day or two just thought i would as on here first if it might be a simple fix.
ps cutting 1/8" cold roll with hypertherm 65 and machine torch.
