Printing trouble
Discussion in 'CNC Cutting' started by OcalaWill, Apr 2, 2018.
  1. OcalaWill
    OcalaWill Well-Known Member
    Jun 22, 2016
    206
    37
    I'm trying to print a selection of my drawing. When I select the geometry and print I get a blank page. I also tried to print the whole drawing and still get a blank page.
    In TM CAD the print preview shows the geometry, but in final Windows print preview (postscript) it is blank. What am I missing? Thanks.
    Instead of Entire Area select Material Area, if the drawing is located within the Material.
  3. OcalaWill
    Jun 22, 2016
    206
    37
    Ok I just had a chance to try this out and still no print. When selecting the Material Area, it wants to print out 30 blank pages! The only way I kind of got this to work is if I select the area I want to print then export it as a PDF, then print the PDF. A bit of a PIB! Also the PDF seems to lose size accuracy (1/16") over 7-1/2".
  4. LECS RC
    LECS RC Member
    Dec 21, 2015
    11
    press fit to page button at the top of the screen next to the setup button on the left. Each of those blue rectangles are a page when printing, that is why you are getting 30 blank pages and only a few of them will have lines on them.
    I would also try turning your show fill on if you don't just want the part to print out in a wire frame.
  5. OcalaWill
    Jun 22, 2016
    206
    37
    Still no luck. And actually none of them have any drawing on them - all blank. What I am trying to get is a 1:1 print out of this part to use as a template as it needs to have a welded section.
  6. LECS RC
    LECS RC Member
    Dec 21, 2015
    11
    What is the size of your part, it looks way bigger than the material blank.
    Also before you go to print press ctrl+A on the keyboard and look in the top left part of your screen.
    It should look something like this, the # may be different.
    If it looks like the next picture you have more than one part on the page.
