Printing trouble
OcalaWill
I'm trying to print a selection of my drawing. When I select the geometry and print I get a blank page. I also tried to print the whole drawing and still get a blank page.
In TM CAD the print preview shows the geometry, but in final Windows print preview (postscript) it is blank. What am I missing? Thanks.
Ok I just had a chance to try this out and still no print. When selecting the Material Area, it wants to print out 30 blank pages! The only way I kind of got this to work is if I select the area I want to print then export it as a PDF, then print the PDF. A bit of a PIB! Also the PDF seems to lose size accuracy (1/16") over 7-1/2".
press fit to page button at the top of the screen next to the setup button on the left. Each of those blue rectangles are a page when printing, that is why you are getting 30 blank pages and only a few of them will have lines on them.
I would also try turning your show fill on if you don't just want the part to print out in a wire frame.
Still no luck. And actually none of them have any drawing on them - all blank. What I am trying to get is a 1:1 print out of this part to use as a template as it needs to have a welded section.
What is the size of your part, it looks way bigger than the material blank.
Also before you go to print press ctrl+A on the keyboard and look in the top left part of your screen.
It should look something like this, the # may be different.
If it looks like the next picture you have more than one part on the page.
