What's causing this?
Discussion in 'Welding' started by SPARKY, Apr 15, 2021.
  1. SPARKY
    SPARKY New Member
    Apr 15, 2021
    I've been welding a long time......and this is the first time I've seen this.
    All the welds on the one side have this tiny hole at the end of the weld, but the other side does not. I've tried setting the heat higher and lower, as well gas the gas pressure. The material is mild black steel and the gas I'm using is
    Argon 75%
  2. Jmartinez19
    Jmartinez19 Member
    Sep 16, 2018
    19
    Dirty material maybe. Grind/Flap wheel that oil residue off the tubing and see what you get? Try a back step at the end as well. I would turn down settings a little as well. Just trying to help. Good luck
  3. stjefrey
    stjefrey Member
    Oct 12, 2018
    11
    Check your filler metal. I've had spools left out in the open and oxidation can occur.
    Jmartinez19 likes this.
