Fastyankee13
OK so I use 14 gauge steel a lot so today I decided to take the time to do a few line speed tests a simple cut test and a voltage test. I'm using 30 amp fine cut consumables on my powermax 45 set to 30 A. I'm also using the 30 settings chart from Hypertherm.
After doing several cuts I determend my best line speed and simple cut speed was 125 ip and 93.2 V.
Cut my first design piece and the cut had lots of dross and I had a hard time getting the blanks to pop loose.
So I'm baffled why is this after running several tests.
So am I to slow to fast the cuts look good but to much dross.
I'm also using a water table.
