I have not added another fan haven't had time and since my box is inside my office its A/C temp controlled probably won't. I'll get some temp numbers next time I run some large files stuff. Also make sure to clean the fan filter. I also would remove the cover and clean the inside. Just be very careful. Some of the early AM3 the driver boards just used clips to hold in the newer one I have is much better design inside.
Normally I only run half the file anyway as depending on what it is I will get stops from torch hitting drops most times anyway. So in Cad-Cam I nest my file on the full sheet. Then will only select say the bottom half of the sheet. Export to cut then when done, cut the top half. I have 4x8 and only cut 4x4 with large small detailed files at a time. And haven't had an issue. I have cut full sheet no issue but parts are large less detail like only 5-6 piece per part and 8x8 in size.
On your PC go to control panel, add/remove program, scroll down to TM-VMD click it to high light at botto info box it says the version newest is 1.3.2 IIR have to look on TM site. They have a download link for newest.
I had 1.2.15 and it lacked the voltage sample under AVHC area.
Under Job setup make sure ohmic is set on (green), its on the far left of the job set window. Next to it I use a partial to raise it 2-3 inches above plate depending on the drops that might get in way I will set it higher. IHS set to always, it will always touch and read plate before pierce. If set to optimal you need to set material thickness just to left it will touch ead then won't again for rest of cutting. I use "always" on thin items or file will few pierces and optimal on thicker stuff 14g with alot of pieces but depends as it saves little time. Use always for now. Also like I said make sure your tip is clean the metal its clean the ground clamp teeth are clean to part. And make sure the wire for Omic cap is routed away from torch lead.
On main VMD display in the AVHC area makes sure its set to auto at top. Set piece height and enter your voltage for the thickness and plasma amp your cutting with. Then click voltage sample to on at very bottom. I always enter book readings for voltage first even with sample voltage on as I have found it works better on first run of that sheet. but with sample voltage it will get better cuts. If AVHC is off it runs on the setting you enter for piece height/run height and will not adjust distance so you want it on.
I called support and talked about the Z issue and can't remember what we came up with. I do know that setting it correctly with newest VMD has helped. I want to say the sample voltage and IHS to optimal it helped the Z creep. I think because lacking the voltage sample before it and running in op it would lose Z position over time as it wan't touching the part every time.
I'll try to get some info on running IHS in the two various settings and get some temp readings. I still say its a temp issue with in the box. But I'll see.
