VMD software guides?
cademaer
Active Member
Just got my table working and I am now looking to hit the ground running. Where can I find info on the simple things like:
Setting cutting speed (I know I get that info from my hypertherm manual, but where do I adjust it in the software?
Calibrating the plate marker offset so it lines up with the plasma torches path.
Importing .dxf files from turbocad/fusion 360 and adding the lead-ins.
Adjusting which parts of a drawing are cut first, AKA cut out the bolt holes in a square bracket before cutting out the bracket body.
Stuff like that. Where are people getting this info?
Thanks!
Just finished watching the vids, very helpful and thank you for taking the time to make them!
I didn't see anything explaining how to align the plate marker to the same point as the plasma though, is there documentation out there that would explain this?
Thanks again!
Very easy to do, jog the torch over the plate and Set Program Zero, click on Tool Library menu and Toggle Tool 1 On, this will drop the torch to pierce the plate, press Toggle again to turn Off. Use the X and Y jog buttons to position the platemarker over top of the pierce hole, then press Set next to Tool 2 for Offset to define that position.
Also if you can tolerate the horrible sound... We have a video/webinar that goes over how to generate and set up the offset in VMD.
