UNABLE TO READ PROGRAMMES IN THE MACHINE
Discussion in 'CNC Cutting' started by vijayabaskar, Jan 29, 2019.
  1. vijayabaskar
    vijayabaskar Member
    Jan 15, 2019
    The programme made from Torch mate when I import to Burny software in the machine. It doesn’t bring any tool path.
    I saved files as .DXF after tool path has been created.
    Machine deatils : Burny Phanthom v8 sprit II 275
    Verify you can open the dxf file into another program such as a dxf viewer that the file is not empty. The Burny controller you may need to ignore layers, in the Cad configuration screen of the Burny controller. For help with this you can contact Burny/Kaliburn.
  3. vijayabaskar
    vijayabaskar Member
    Jan 15, 2019
    I have attached the CAD configuration setting image below. pls do check if everything set as ok.
    We are still not able read programmes.
  4. vijayabaskar
    vijayabaskar Member
    Jan 15, 2019
    New question.
    I was trying to cut 26 mm hole on 25mm thick plate but the hole become tapper 28mm/24 mm. How do i get correct hole size with no tapper .
    MAchine/Setting.
    TorchMate Burn Kaliburn Sprit 275 A
    200 Amps
    Feed Rate 1190 mm/min
  5. Dnmeistr-LECS
    For plasma settings you will need to contact Burny/Kaliburn. In your Cad settings set Ignore Layer to 1.
  6. vijayabaskar
    vijayabaskar Member
    Jan 15, 2019
    Hi Dnmeistr,
    How can I use torch mate to make programmes and run using Burny kaliburn,
    IS Burny Kaliburn supports Torchmate programmes? . Please do share your thoughts.
  7. Dnmeistr-LECS
    You can use TM Cad to create dxf files, if you have Cad 8 or 9 you will not create a tool path the Burney software would create the tool path for you. When you export the dxf from TM Cad you will want to uncheck the box Tool Paths Only, as you are not going to export a tool path but you are going to export the original dxf file you create. Import the dxf file into the Burney software as you would with any other dxf file.
