Torchcad Weld issues
Discussion in 'CNC Cutting' started by Cypress, Mar 9, 2019.
  1. Cypress
    Cypress Well-Known Member
    Mar 11, 2016
    51
    46
    98
    So recently I've been having issues with welding object together. Specifically these split monogram letters. I tried them in DXF but when I try and weld a letter to the split letter it doesn't weld...and when I click on the object and move it the shape of the object is now missing from the Monogram letter. I converted the letters to PDF but it would still do the same thing...the interesting thing is some letters would take a weld and others would not. Any Ideas?
    Likely you have different colors being used. Go to View > Pallets > Job Pallet if you have more than one color showing on the right side of your screen then the weld tools will not perform as expected. Select all then left and right click on the black color at bottom of screen to merge layers.
  3. Kchoghead
    Kchoghead Well-Known Member
    229
    35
    Layers...all items need to on the same layer-color I
  4. BlueSteel
    BlueSteel Well-Known Member
    Dec 15, 2016
    104
    88
    I usually highlight all my stuff and left click then right click on the color I use. Then right click left click. I dont remember which combination works so I do both and it usually fixes it
  5. JoshAK
    JoshAK Member
    Oct 2, 2017
    I’m having issues with my weld tools. The part I’m drawing won’t let me weld to it. The part disappears and the shape I’m trying to weld to it stays.
  6. JoshAK
    JoshAK Member
    Oct 2, 2017
    Found my problem. Had open contours, objects wizard fixed it. Haven’t tried cutting yet but welding is working again.
