How can I change where the plasma will start the cut once a toolpath has been created? When I have tried to change where it starts, I loose the ability to create a dxf from an edu file when I want to export the file.
double click the piece and move where you see your lead in or out.
Or go to Machine -> edit start points and just click on the new spot you want to start for each cut. Just click the line and it will move the lead in. If you don't click the line it will exit the start point editor
