TM CAD/CAM V9 exporting dimensioned drawings for printing?
Discussion in 'CNC Cutting' started by Dangerville, Aug 17, 2016.
  1. Dangerville
    Dangerville New Member
    Aug 17, 2016
    I'm old school. I like to have hard copies on paper of my dimensioned drawings, so that if, gods forbid, there's a crash or virus on both my laptop and backup hard drive, I can quickly re-create the drawing that I've spent the last six months putting into TM CAD, or send the parts to another company for cutting in the event of an equipment failure.
    I've been experimenting with how to do this in CAD/CAM V9, but I can't seem to figure it out. When I export the image as a .pdf, the dimensions don't show up, and when I export as .pdf or .bmp, both images are very light in color, and unprintable. Any help would be appreciated. Thanks.
  2. Dangerville
    Aug 17, 2016
    BTW...notes on the image don't show up, either.
  3. Matt
    Matt Well-Known Member
    112
    Try using the publish to pdf option
  4. Dangerville
    Aug 17, 2016
    When I publish to pdf, the part image comes through very light, and none of the dimensions or notes are visible.
  5. noclinkers
    noclinkers Active Member
    Feb 15, 2016
    29
    I use the stroke and fill to embolden the lines.
  6. Charles Hinze
    Charles Hinze Member
    Jan 20, 2016
    11
    I hit print screen and then paste into photoshop (paint) works as well
  7. LECS-Chad
    A few things to verify when you are generating PDFs out...
    1. Make sure you are selecting a font and font size that is large enough to see.
    I will usually select either Times or Arial and set them to BOLD and at least Size 20.
    2. I will use the VIEW/SHOW FILL option to allow for the part to come out solid instead of lines but if you are needing to use the LINE view then you can select your item and add some weight to the lines by using the STROKE TOOL. upload_2016-8-19_9-13-25.png
    Select your part that you need the weight and select the PEN tool.
    Make sure THICK LINE is selected
    Enter in at least .1 for the line thickness
    This will automatically add the weight to what you have selected.
    Then select all.
    File/PUBLISH to PDF
    Have SELECTED CHECKED. UNCHECK TOOL PATHS ONLY. Name the file.
    In the PUBLISH screen
    Make sure EXPORT VECTORS AS SHOWN ON SCREEN is checked. Press OK.
    Should get good results...
    ;)o_O
