IndustrialRustic
Member
Red box signal generator getting error code 18003 cannot connect. Heres what I know:
All the lights work as should, cycles all green and then usb is lite orange
When plasma is on it triggers the air as it normally did
When I unplug the usb it does make the double beep noise
When I connect the usb it makes a different noise ( that's where something isn't correct)
I have tried different usb ports
Different usb cable
Disconnected everything and reconnected
still wont connect
Nothing appears fried inside the box..................
Different usb cable
still wont connect
