Kind of figured it out - I have to Ginsu knife the area off the main I want to rotate then I can do it. If there is an easier way I'd like to know. Thanks!
Then reshape it in NODE EDIT MODE. Once finished then press APPLY at the top. ARRANGE/BREAK PATH rotate the piece the way you want it. Then ARRANGE/MAKE PATH once you are done.
