Reducing Cut Bevel
OcalaWill
How to minimize - air pressure and/or torch cutting height? I am running pretty much recommended settings for FC80 except 50-60 PSI to reduce some water splashing. Thanks.
I wouldn't drop the pressure below 60 psi, you will notice the torch purges air this is to ensure the consumables cool down properly and do not get overheated, too low of pressure is going to have diminishing returns. To compensate for bevel use recommend cut height and drop your cut speed, this will result in more dross that is easily removed the upside is it reduces the amount of bevel.
