pre programmed cuts
DanGeorgian
i guess some things got deleted in the process of getting things working.
is anyone willing to share their file that is called "line speed test"?
TIA
you can either use the slider or generate your own by bringing the .gm file into a text editor. Then after every F change that number and that will be the feed rate
