Power supply voltage
Larry Cameron
Hi guys final query.
Attached are pics of Torchmate Controller but in the unit it shows 250volt but the plug shows 125volt.
So what should the voltage be?
We have 240volt here but I purchased a step down transformer to get 110volt with USA plugs.
But after looking at the unit and plug I don’t know how to proceed.
The fuse is a 250v slow blow fuse, this is standard for most electronics. The input voltage is 125v, standard household current here in the States, the plug you have is correct.
Thanks so this will be ok to run through a step down transformer 1000watt from 240 to 110 volt for USA Machinery?
