If you are just jogging the torch down to the material you will need to first turn the relay on, under Machine Settings and Advanced Tab set Relay Output to On, this way you can test the ohmic circuit. If when the relay is on you can use a test wire to go between the orange wire to the VFC ground screw and work your way back from there to the material you will see where you are getting the disconnect. Material needs to have continuity to the VFC ground screw.
