JEL DESIGNER
I have an Accumove 3 controller with a Flexcut 125 plasma unit. The table is a Table X 6 x 14. When doing a dry run of a program my torch head comes down hits the material and causes the light to come on. The program will not continue. We have the debounce set to 5 for the ohmic cap. There are times when we reset the program it works on the first hole we have in the program moves to the next line of the program and then we have the issue again. I am not sure what is going on. We are trying to cut 3/8" hr plate. The table is grounded well. I also have a ground wire attached from the grounding point on the table to a slat. We have called tech support and the person my operator talked to told him to adjust the debounce time and that did't work. This is a issue we don't want. We did some cutting Friday night with no issues. We also used the plate marker with no problems. We are unsure of what to do next. We need to get these parts cut and get on to the next parts to cut. We are falling behind in our production with these issues.Thanks for any help.
