Kathalee Cole
Member
New to this so we are trying to dial in our new Torchmate 4400 machine. We run a flexcut 80 machine and we are cutting 16 gauge and 11 gauge metal. I recently purchased a Precision tip to help with the small cuts. I tried the settings tonight from the book and had issues with it not wanting to cut all the way thru the metal. My feed rate when I turned in into a g-code was set at 100.
AVHC settings are as follows:
Mode-Auto
Sample Voltage-On
IHS-On
IHS Mode-Optimal
Cut Charts-Charts
Cut Parameters are as follows
Pierce Height-0.16
Cut Height-0.30
Pierce Delay-0.10
Retract Height-1.00
Arc Voltage-110.00
Question is what should my settings be to get the best cut with the less dross and to cut thru the metal.
How small of a design can you cut and how intricate of a cut can you make? I've attached sample Jpg of cuts that we are working on. Any and all help is greatly appreciated.
Mode-Auto
Sample Voltage-On
IHS-On
IHS Mode-Optimal
Cut Charts-Charts
Pierce Height-0.16
Cut Height-0.30
Pierce Delay-0.10
Retract Height-1.00
Arc Voltage-110.00
