multiple toolpaths when only 1 is wanted-needed
Southern Sparks
New Member
hello i am new to the forum and have one file drawing that is just a poly-arc drawing and when i go into make toolpath-male etc it makes multiple toolpaths and can not figure out whats going on with it any help would be great thanks,
A picture would be nice so we can properly diagnose the issue. You could have duplicate lines or open objects causing the issues, for either issue Select All and Break Path, be sure the number of objects shown selected (upper right of your screen) matches the total number of objects shown, delete duplicates till numbers match. Open objects can be found by Edit then Select by Open Objects. After issues are fixed Select All and Make Path then turn on Show Fill to determine WYSIWYG.
