multiple layers
Discussion in 'CNC Cutting' started by bigjoe, Oct 20, 2016.
  1. bigjoe
    bigjoe Well-Known Member
    Jul 21, 2016
    156
    10
    88
    can more than one sheet of thin material be cut ? or will they get welded together, I imagine the middle pieces will have no dross
  2. Larry Cameron
    146
    29
    I haven't tried it but a mate of mine who ran commercial plasma cutters said he did but stuck the plates together with a thin coat of oil.
    Larry Cameron
  3. LECS Matt
    LECS Matt Member
    Oct 19, 2016
    7
    BigJoe there are multiple reasons not why this could potentially not work. First is the possibility that they will get welded together either from the heat of the torch or the oils on the material bind together through the plasma. Secondly, depending on how thin the material is, the air pressure from the plasma head can air build up between the plates causing some of your upper plates to move and fluctuate resulting in parts that aren't right and loss of material. It might work, but better safe than sorry depending on what you are cutting.
  4. Dnmeistr-LECS
    This sounds like a recipe for disaster, lol.
    Torchmate likes this.
  5. bigjoe
    Jul 21, 2016
    156
    10
    88
    all input is appreciated, there I go thinking out loud again
  6. Arkansas Metal Art
    515
    270
    I haven't cut multiple layers on my table but I always cut multiple 4x8 sheets down with my hand held (powermax 45) at the same time. I cut three 14g 4x8 sheets at once. I'll cut them down into 2x4 pieces to fit my table. Saves a ton of time. I have no issues doing it. But I agree with the others, I wouldn't attempt it on my table, at least not for anything more than a straight line to sever a sheet. I have cut two sheets at once on my buddys 5x10 table for the same reason with no issues but again just cutting straight lines to piece out larger sheets, not cutting parts.
  7. 61 Sunliner
    61 Sunliner Active Member
    May 22, 2016
    34
    I cut 2 and 3 sheets of 16 gauge on my 2x4 table. Though just straight line cuts sheering them down to 2'. They stick together a little on the cut edge but pop right loose.
    Mike
  8. bigjoe
    Jul 21, 2016
    156
    10
    88
    ok cool , I think I will use my handheld as well for now ..
