manual height control and pierce move delay
Discussion in 'CNC Cutting' started by Tyler Ude, May 3, 2016.
  1. Tyler Ude
    Tyler Ude Member
    May 3, 2016
    11
    i have a 2x2 with esab powercut 1300 plasma. The machine is working and cutting fine but i have one annoyance with it. Ive emailed support but they stopped helping when i said it was a manual height control.
    basically whats happening: I hit start on the program. The table jogs out and the plasma will fire and it will immediately start moving, cutting out the section. Once it stops and jogs to the next pierce point, it will pierce and then sit there for 3 seconds before moving. Id like it not to sit there.
    In the M code definitions i have the "Plasma On" set for a 3 second delay. If i lower it, the very first pierce on the program gets messed up. The machine will actually start moving before the torch fires and it will leave a small gap in the cut. All of the other pierces in the program will have the correct delay time that is set.
    How do i get the first pierce to delay the same as the rest? I asked on pirate and they said that i need to hook up the "okay to move" or as my esab calls it "motion allow" to the Torchmate but all the wiring diagrams i have, thats for AVHC and not the manual control. Can i still hook that up? what pins on the 501A box does it need to go to?
    here is the M-Code Definitions:
    [​IMG]
    LECS-JR and LECS-Soto like this.
    You would be using the INPUT on the sig gen. So you would require the INPUT cable and attach those said wires to it. Then you can set that INPUT as your "motion allow" in the M-CODE TO EXECUTE MACROS. This would work as your OK TO MOVE to help resolve the pierce issue you are having.
    LECS-JR likes this.
  3. Tyler Ude
    Tyler Ude Member
    May 3, 2016
    11
    okay, thats about what i thought. I have a cable/connector to plug into the input. Do i just pick 2 pins for my "motion allow"?
    You went a bit over my head on the setup of it in the driver software. I dont see anywhere in the Input section or under the Macro's that would give an okay to move signal. Can you be a bit more specific on what i need to change or do?
  4. Tyler Ude
    Tyler Ude Member
    May 3, 2016
    11
    i think i got it:
    from pirate: http://www.pirate4x4.com/forum/torc...-pinouts-mo-501a-controller.html#post13240782
  5. LECS-Chad
    Yes that is correct.
