Dan Turner
Again with this is so simple, why did I have a problem with it???
When I draw, I always want my part to be in the (0,0) position on the table.
When I finished drawing a part and I was satisfied with the result, I created a male cut path. When I went to the machine output to cut the image to a .gm file, an error message came up saying there was nothing to cut. After much experimentation and walking away from the table for a breather, I figured it out. When I created the cut path, the drawing went into (-0, -0). Once I moved the drawing into positive territory and onto the drawing plane, it cut just fine.
I hope that this helps someone else.
