Dillon Garcia
New Member
Does anybody know why my machine would be cutting everything out jagged? My high school has had nothing but troubles since we got the new 4x4 setup.
It does not cut jagged doing straight lines only when cutting curves.Can you post pics of the cut piece and possibly a short vid of it actually cutting? Can you post the dxf file your cutting? Does this happen with every cut?
But the machine cuts perfect on other cuts at times. I'll try and get a video of the torch in a run and see what you guys thinkFinding the problem is easy, just as Chad said, grab the torch and shake it, it is the same effect that is happening when cutting, simple as that. Find out where you are getting the slop/backlash from and tighten it up.
