OcalaWill
I’ve been cutting some designs that have concentric circles and have an issue where the material between the cuts gets narrower or wider at different points. So I checked the table for level and squareness and it is ok. What I found is the lifter station will rock in the Y axis direction if I grab a hold of it by hand. Could this be the issue? I took the lifter station off and some of the bearings will rotate if I touch them (not contacting track). What is the adjustment procedure for this? I went thru the manual and couldn’t find anything. Table is a 4x4 GS. Thanks.
