HOW TO CREATE A PEIRCE POINT
Discussion in 'CNC Cutting' started by JEL DESIGNER, Dec 3, 2022.
  1. JEL DESIGNER
    Apr 28, 2017
    62
    I want to create a Pierce Point to locate a hole center for drilling. I know this will harden the material at this area but my holes I will be drill are larger diameters than the Pierce Point.
    I am trying to do this as we have some holes that are close to material thickness and don't cut well.
    I also want to try to reduce our maching cost by having a hole center located.
    I do not use the CAD/CAM software for CAD. I use other CAD software to create DXFs to import.
    My CAD software has a Point option I can use when creating my DXF.
    I am going to run a test program with a part that I used this Point option.
    When doing the Pierce Point is there any setting I need to use in the Creating Tool Path?
    What Tool Path should I use on the Pierce?
    Will this change with different material thickness?
    Any help with this would be appreciated.
