How important is motion control?
Torchmate
Administrator
Staff member
The motion controller is the brain behind the table’s operations. It is the Computer Numerically Controlled part of the term “CNC plasma cutting table.” The way a controller operates a table is completely dependent on the quality of software engineering that has gone into the controller, and Lincoln Electric is confident in the processing power and ease of use that has resulted from our long-term dedication to this department.
The weight of a table’s performance is heavily dependent on the motion controller. Every line of g-code needs to be accurately interpreted and sent to the correct component; doing this quickly and accurately can lead to big advances in table performance. Our controllers use large processors to read hundreds of lines of g-code in advance in order to accelerate and decelerate the motors at faster rates. This increased processing power triggers a finer control of the plasma and can lead to better cut quality, faster job completion times, and longer consumable life.
Discuss everything about motion control below!
They have other systems that interact with the different controllers. I know there are some linux based systems. PC is just a cheap option that everyone has access too...
