Fastyankee13 Well-Known Member May 17, 2017 #1 I'm wanting to add Ohmic sensing to my 30a tip. My machine works way better with Ohmic sensing in use.
D Dnmeistr-LECS Well-Known Member May 18, 2017 #2 Make your own, very easy to do. If the nozzle protrudes past the shield you will need to make ohmic contact before the nozzle touches the material.
Fastyankee13 Well-Known Member May 20, 2017 #3 Thanks for that info. I was looking for input on how others have done. Can I run a rod down so it touches the material at the same length as the tip?
B bigjoe Well-Known Member May 20, 2017 #4 stainless hose clamp around torch cap end , trim end and attach terminal clip
